TwinTurbo.NET: Nissan 300ZX forum - Whoops - 245/45/16. 16x8.5 TT stockers front & rear (n/m)
black300zx
on June 25, 2012 at 8:46 PM
What 15" wheels are you using? (n/m)
posted by Fast300
on June 25, 2012 at 08:03 PM
Brake rotor advice.
Vert93 (MN)
16:45:37 06/25/12
If you are planning on selling then replace w. stock
16:53:47 06/25/12
If the Brembo rotors will do the trick w/o warping, then
Vert93 (MN)
17:00:42 06/25/12
He's saying since you plan on selling, replace with a
samsung-Z [Houston]
18:08:03 06/25/12
Actually, it was Stop Tech brake pads, not Hawk HPS... (n/m)
Vert93 (MN)
16:54:22 06/25/12
...and stop beating on it. (n/m)
02:02:40 06/26/12
the stock sized rotors are too small for that much power
moxie (SF)
18:24:07 06/25/12
Im running the stocksize stoptech rotors that IPP sells
black300zx
19:30:06 06/25/12
the weight is only half the issue. The power plays
moxie (SF)
19:34:44 06/25/12
Fast300
20:03:37 06/25/12
Whoops - 245/45/16. 16x8.5 TT stockers front & rear (n/m) -
black300zx
20:46:15 06/25/12
I had great results with ATE rotors with the stock size.
ShakaShaun(Denver)
20:16:38 06/25/12
Thanks for all of the suggestions. Hopefully one of them
Vert93 (MN)
08:36:12 06/26/12
You don't seem to be bedding them in and I agree w. TDogg (n/m)
09:14:11 06/26/12
The rotors didn't warp, you had uneven pad deposits.
09:07:22 06/26/12
Tony is right, you wont warp the stock discs, the fluid will
10:03:34 06/26/12
I'll third what Tony said - what was your bed-in procedure?
black300zx
16:29:11 06/26/12
key is don't stop until you can smell them from inside (n/m)
16:59:22 06/26/12
oh I was smelling em alright! (n/m)
black300zx
18:27:26 06/26/12
